How to set port status based on other port status
Ask in here.
btorrenga
Post by btorrenga »
It seems these should be simple to code, but I can't wrap my head around it.
Two things I want to do:
1) I want to turn a port on whenever a different port is off. No doubt going to use the "!" boolean somehow, but I don't know which functions.
2) I want to turn a port on for 1 hour before the metal halides come on, and one hour after the metal halides come on. This one is a bit trickier, probably using some math functions.
Any suggestions?
Re: How to set port status based on other port status
ReefAngel.Relay.Set(Port1,!ReefAngel.Relay.Status(Port2));
2)
If you use internal memory:
  ReefAngel.DelayedStartLights(Port1);
  ReefAngel.ActinicLights(Port2);
If you prefer hardcoded:
  ReefAngel.MHLights(Port1, 9,0,20,0,5);
  ReefAngel.StandardLights(Port2, 8,0,21,0);
btorrenga
Post by btorrenga »
Interesting, but where can I read about how to use DelayedStartLights and ActinicLights functions? Is there a source file with comments I can look into?
It's inside ReefAngel.cpp
