My dosing pump code is rather long/outdated. I noticed several changes to this function. Just curious if there's a cleaner way to do it than my current code, which has them turn on at midnight dosing 2-3 secs every hour until 6am. I was hoping to use the new DosingPump/DosingPumpRepeat functions to dose the same intervals, only starting at 10pm instead of midnight. Here's my current code (which doesn't take into account dosing before midnight):
//Dose Alk
if ( ReefAngel.DisplayedMenu == DEFAULT_MENU ) //Alk Doser - Only works if Main screen is showing
/* && = and || = or
Hours between 12:05am and 6:05am
minute must be 0 (top of the hour)
seconds less than 3 (up to 3 seconds)
if ( ((hour() >= 0) && (hour() <= 6)) && (minute() == 5) && //dose time
(second() < 3) ) //dose duration
ReefAngel.Relay.On(AlkDoser);
ReefAngel.Relay.Off(AlkDoser);
If this is still the way to do it that's fine, I just wasnt sure how start at 10 pm since using
Chase try that out and let me know. My dosing has been a little weird since 9.9 as well. I'm using the code Roberto posted above but my dosing has been way less overnight versus before 9.9 libs (I have my holding containers marked in 10mL intervals)
Great thanks for the quick reply! I'll give it a try once I have a chance to monitor it as well and post my results. Messing with dosing routines is always scary! =)(
