Okay need some help already.
Piper27
Post by Piper27 »
So I am trying to generate the memory and not really sure what to do. Also when I just hit generate then the launch buttom its not even showing a serial port as an option.
Re: Okay need some help already.
Are you talking about the RAGen?
When you hit generate, it creates a file called Memory_xxxxxx with a timestamp in place of xxxxxx.
Go to File->Sketchbook and you will see it there.
By the way, have you tried the new Reef Angel Wizard?
http://forum.reefangel.com/viewtopic.php?f=8&t=1297
Piper27
Post by Piper27 »
I had it plugged in wrong heh, lets see how far I get now I may be back shortly with a question!
Piper27
Post by Piper27 »
Well I got the com port to work I think and everytime I try and generate with ragen and then upload with arduino it says "color white was not declared in this scope"
Can I see the code?
Piper27
Post by Piper27 »
Ahh I didn't try the wizard, I am messing with it now.
Piper27
Post by Piper27 »
Ok so the wizard seemed to upload everything ok. Got the com3 working and uploaded the internal memory.
Now when I try to setup the wifi the attatchment connects to the computer but when I put my login name and password it says it can't connect to my wifi. Is there settings on my computer I need to change? The ssid and password are the same ones I use to login with my phone right?
Yes, it is the same.
What type of security are you using?
It's recommended you use WPA2-PSK with AES encryption.
Piper27
Post by Piper27 »
Is all I know is it's norton.
I'm talking about your wifi security, not computer.
Piper27
Post by Piper27 »
I think I got it. Time to go see if it all works.
Piper27
Post by Piper27 »
Haha yea I had to read up on what that meant thanks for the help!
