Your comments and thoughts are welcomed.On the parameters monitored question, (pH/temp/ORP/salinity/Alk-dKH/other), I see temperature and pH as the big winners. No votes for alk/dKH - is there no automated monitoring, or just too expensive? What are the "Other" parameters that people are watching via the controller?
What all can we monitor?
rossbryant1956
We are discussing the relative merits of RA over other competitive brands and the question came up around:
Re: What all can we monitor?
Alk-dKH is explained in depth by Randy and I can google and find his article.
I think the only way to do it is by titration and color change, so you would need a very precise piece of equipment to mix reagents and a colorimeter to look for color changes.
Then, you need to make sure you dispose and clean all the equipment by flushing with RO, so it doesn't affect future readings.
I think it is just too expensive. There is no such thing as a simple probe for that. Probes are ion selective. They have a very thin PVC membrane that lets only specific ions to pass. By doing so, it creates an electric voltage between the inside and outside of this membrane. This is the voltage that can be measured and interpolated to give you scaled readings.
Alkalinity is not an ion. It's the abilitity to neutralize acids.
I hope this helps a bit
