I would want the outlets controlled with the following:
Day lights - on/off at daylight/dusk
actinic lights - on/off 45 min before and after day lights
moon lights - on/off opposite day lights
CO2 - off on at pH 7.9 - can I set off at 7.85, then back on at 7.90 - so it's not constantly going on/off?
non-controlled tunze - on for 3 hours, off for 6 on for 4 - only from 8 am until 9 pm - same every day
fan- on when when water temp > 79.5, off when water temp <79.5
return pump - can go off with feeding mode (although I use this more for photo mode
skimmer - same as return pump
So - I am totally illiterate when it comes to programming this stuff...I have tried to read the forums, but I am just more confused...
I even tried to just look at the menus on the controller, it is supposed to have the following menus -Feeding
Water Change
Lights ->
Temps ->
Timeouts ->
Setup ->
Version
Exit
where are these menus? I have 14 options in the menu and none are those as listed above...
