Need a little help
Ask in here.
dtzreef
Need a little help
Post by dtzreef »
So I got a great code for my custom menu from psyrob (thanks buddy), I just need to change a couple of things inside the code. I need to change port#2 to a skimmer port (off during water change and feeding time) and the light ports. Blue led (port #3) and Day led (port#4). I really like how psyrob has the wavemaker functions set up and I realy dont want to loose that. Could someone point me in the right direction. I tried cutting and pasting from the wizard and RaGen but obviosly I'm doing something wrong. Any help would be much appreciated!!!!!
// Autogenerated file by RAGen (v1.2.1.158), (02/18/2012 23:31)
// RA_021812_2331.ino
//This is the latest; 02/20/2012 wavemaker timer added
#define VersionMenu
#define wifi
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
byte wmport=Port5;
boolean wmdelay=false;
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 118, 119, 118);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Main Tank:");
char text[7];
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 88, 15, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 46, "pH:");
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 46, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,25,"Frag Tank:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 88, 25, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,36,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 88, 36, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 38, 57,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,105,64,t);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
ReefAngel.Relay.On(Port5);
// Specific functions
ReefAngel.StandardATO(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.MHLights(Port4);
//ReefAngel.Wavemaker1(Port5);
//ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardFan(Port8);
//wavemaker timers and slow down at night
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6; else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
ReefAngel.Portal("psyrob");
Re: Need a little help
Try this:
byte wmport=Port5;
  char text[7];
  if (t>=0)
  ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
  ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
  ReefAngel.Relay.On(Port2);
  ReefAngel.StandardATO(Port1,60);
  ReefAngel.StandardLights(Port3,7,0,19,0);
  ReefAngel.StandardLights(Port4,7,0,19,0);
  ReefAngel.StandardHeater(Port7,770,780);
  ReefAngel.StandardFan(Port8,780,790);
      if (wmdelay)
        else wmport=Port5;
        wmdelay=false;
        wmdelay=true;
  ReefAngel.Portal("dtzreef");
dtzreef
Post by dtzreef »
Thanks so much, I'll try it tomorrow when I have time to study what you did. I gotta say, so far you have lived up to your reputation!!
dtzreef
Post by dtzreef »
Perfect! Except one teeny little thing that I forgot to mention. I need Port #8 to be the main pump and off during water change. I promise I won't bother you for at least a week.? Which program (RAGen, wizard, client would I use to make these small changes? Or do I just need to learn the code? Thank you one more time for your help!
Try this then:
byte wmport=Port5;
  char text[7];
  if (t>=0)
  ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
  ReefAngel.Relay.On(Port8);
      if (wmdelay)
        else wmport=Port5;
        wmdelay=false;
        wmdelay=true;
dtzreef wrote:Perfect! Except one teeny little thing that I forgot to mention. I need Port #8 to be the main pump and off during water change. I promise I won't bother you for at least a week.? Which program (RAGen, wizard, client would I use to make these small changes? Or do I just need to learn the code? Thank you one more time for your help!
I'd recommend using the wizard to make the change since it remembers your choices. OR you can make this small change manually:
I added the "| Port8Bit" to the end to turn port 8 off during water change as well.
