straight forward float valve control
rossbryant1956
Re: straight forward float valve control
Post by rossbryant1956 »
First Question:
rimai wrote:Try this:
//turn off port 8 - main pump when switch is tripped and sound buzzer
     ReefAngel.Relay.Set(Port8,ReefAngel.IO.GetChannel(0));
     ReefAngel.PWM.SetDaylight(100-(ReefAngel.IO.GetChannel(0)*100));
This works as designed. Thanks. As I was testing, I got to thinking, however. I read a blurb on here recently where once the overflow trips, you want it to stay tripped until you can get to the tank and clear the blockage or whatever was causing the overflow switch to stop the pump. This would prevent the tank from draining, resetting the float switch, restarting the pump until it backed up and tripped the switch again. Is this possible?
Second Question
Oh, in this case it is simple.
You can use one of the custom variables.
CODE: SELECT ALL
ReefAngel.CustomVar[0]=ReefAngel.IO.GetChannel(0);
ReefAngel.CustomVar[7]=1;
Then, on the Portal, you can set a trigger to send you alerts when C0 = 0.
How long does it take the portal to pick up these alerts and send out the emails? Again I was testing tonite, held the switch tripped for 40-50 seconds, at least, but still didn't send. LMK and Thanks as always.
The controller sends data to portal every 5 minutes.
rossbryant1956
so that means it would have to stay tripped for whatever length of time elapses from when it happens until the controller next sends, yes?
Then that makes my first question very important... how do you make it stay tripped, once tripped? THx
Wouldn't it stay tripped if it does trip?
rossbryant1956
actually no. The water level in the tank with the pump off is below the float valve. So when the water rises enough to trip the float valve, the pump stops and the water level falls (which is what I want.) However, under the current design when the water falls, it resets the switch and the pump turns back on.
While this is not catastrophic I was referring to the post regarding letting a pump cycle on and off and it not being good for it. LMK what you think. Thx
Is it an overflow you are trying to measure or is it something else?
Just curious.
If you want to make it trip and disable the pump until you inspect, we can do that.
Right now, it will turn on /off the port depending on the state of the float switch.
We can also leave the pump the way it is and make the custom variable stick, so if it does trip, the custom variable will change and not go back until you inspect.
Which one you prefer?
rossbryant1956
It is an overflow and it is working like you said...
Your idea:
sounds like exactly what I want. Keep in mind we have a setting on the portal to send a email\text message when CustomField0 changes from 1 to 0. Don't want this new code to override that. Thx
Change this:
To this:
if (ReefAngel.IO.GetChannel(0)) ReefAngel.CustomVar[0]=1;
It will require you to reboot the controller once the flag is set, though.
You shouldn't be having this happening at all to begin with.
If you are, there is an underlying problem and this is not going to be your solution.
rossbryant1956
You are right. I am attempting to fix a problem with my glass-holes overflow, but this is not the answer. I'll keep thinking. Thx
