Problem with dev library 1.0.0
Re: Problem with dev library 1.0.0
The MoonPhaseLabel is broken :(
See the posts above.
The rest is fixed:
// Autogenerated file by RAGen (v1.2.1.158), (03/08/2012 22:54)
// RA_030812_2254.ino
The following features are enabled for this File:
#define DisplayImages
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define SALINITYEXPANSION
#define RFEXPANSION
#define FONT_8x8
#define FONT_8x16
Ports assignment:
Port1 - Return Pump
Port2 - Circulation Pumps
Port3 - Heater
Port4 - Skimmer
Port5 - Tunze ATO
Port6 - PWM Expansion Power Supply
Port7 - Fuge Light
Port8 - Fuge Moonlight
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// Globals Needed for Params on Custom Main
byte x,y;
int v;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
byte vtechspeed;
byte vtechpercent;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
        //Top Banner
        ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 9, 2, "WISEGUYS' REEF");
        ReefAngel.LCD.Clear(DefaultFGColor,3,11,126,11);
        // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,15,"Tank");
        char text[7];
        // Display the T1 Temp Value
        ReefAngel.LCD.Clear(255,4,26,125,41);
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 26, text, Font8x16);
        // Display the Salinity Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,55,15,"Sal.");
        // Display the Salinity Value
        ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 57, 26, text, Num8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,105,15,"pH");
        // Display pH Value
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 26, text, Font8x16);
        //Display Alternate Temp Parameters
        ReefAngel.LCD.DrawText(0,255,8,45,"Sump");
        ReefAngel.LCD.Clear(255,36,45,57,52);
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 36, 45, 10);
        ReefAngel.LCD.DrawText(0,255,72,45,"Hood");
        ReefAngel.LCD.Clear(255,100,45,119,52);
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 100, 45, 10);
        // Display Vortech MP10wES Mode Header Text
        ReefAngel.LCD.Clear(DefaultFGColor,3,56,126,56);
        ReefAngel.LCD.DrawText(0,255,18,60,"Vortech EcoSmart");
        // Display EcoSmart Mode Value & Speed %
        ReefAngel.LCD.Clear(255,1,71,128,78);
        vtechspeed = InternalMemory.RFSpeed_read();
        vtechpercent = vtechspeed * 0.39215;
        ConvertNumToString(text, vtechpercent, 1);
        if (vtechmode == 0)
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,16,71,"Constant-");
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,89,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,106,71,"%");
        else if(vtechmode == 1)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,20,71,"Lagoon-");
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,85,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,102,71,"%");
        else if (vtechmode == 2)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,8,71,"Reef Crest-");
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,97,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,114,71,"%");
        else if (vtechmode == 3)
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,4,71,"Short Pulse-");
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,101,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,118,71,"%");
        else if (vtechmode == 4)
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,8,71,"Long Pulse-");
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,97,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,114,71,"%");
        else if (vtechmode == 5)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,4,71,"Nutrient TM-");
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,101,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,118,71,"%");
        else if (vtechmode == 6)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,4,71,"Tidal Swell-");
        else if (vtechmode == 9)
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,28,71,"Night-");
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,77,71,text);
          ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,94,71,"%");
        // Display PMW Expansion Channel Headers and % Values
        ReefAngel.LCD.Clear(DefaultFGColor,3,82,126,82);
        ReefAngel.LCD.DrawText(0,255,3,85,"D:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(), COLOR_CORNFLOWERBLUE, 13, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,33,85,"%");
        ReefAngel.LCD.DrawText(0,255,48,85,"A:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(), COLOR_CORNFLOWERBLUE, 58, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,78,85,"%");
        ReefAngel.LCD.DrawText(0,255,92,85,"M:");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetChannelValue(0), COLOR_CORNFLOWERBLUE, 102, 85, 1);
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,122,85,"%");
        // Display Moon Phase during night and Sky Type During Day
        if (ReefAngel.PWM.GetChannelValue(0) > 0)  //If Moonlights are active
           ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,6,94,"    Clear  Skies");
        // Display Main Relay Box
        ReefAngel.LCD.DrawOutletBox(13, 104, TempRelay);
        //Draw Date & Time
        ReefAngel.LCD.Clear(DefaultFGColor,3,118,126,118);
        ReefAngel.LCD.DrawDate(6, 120);
void DrawCustomGraph()  // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
    ReefAngel.FeedingModePorts = Port2Bit | Port4Bit; // Turn off Port2 and Port4 when feeding mode is activated
    ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit; // Turn off Port2, Port4 and Port5 when water change mode is actived
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port7Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port6);
    vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
    // Specific functions
    ReefAngel.Relay.DelayedOn(Port4, 1); // Turn on Port 4 (Skimmer) with 1 minute delay
    ReefAngel.Relay.DelayedOn(Port5, 2); // Turn on Port 5 (Tunze ATO) with 2 minute delay
    ReefAngel.StandardLights(Port8); //Fuge Moonlight on when main lights are on
    ReefAngel.StandardLights(Port7,20,30,8,30); //Fuge Light on at night
    ReefAngel.StandardHeater(Port3); // Standard Heater Using Internal Memory
    // LED FunctionsPWMSlope based on Internal Memory values for Standard Lights
    ReefAngel.PWM.SetActinic(PWMSlope(8,30,21,30,25,80,120,0)); //Set Blue LED during daytime, off at night
    ReefAngel.PWM.SetDaylight(PWMSlope(8,45,21,15,25,80,120,0)); //Set White LED during daytime, off at night
    if ((hour() >=8 && minute() >=30) || (hour() <= 20 && minute() <30))
      ReefAngel.PWM.SetChannel(0,0); // Turn off moonlights during daytime
      ReefAngel.PWM.SetChannel(0,MoonPhase()); // Set Moonlights to MoonPhase during night hours
    // Fan Speed Functions
    signed int HoodFanSpeed;
    HoodFanSpeed=map(ReefAngel.Params.Temp[3],750,900,25,100); // Calculate Hood Fan speed
    HoodFanSpeed=constrain(HoodFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(1,HoodFanSpeed);
    signed int BlowerFanSpeed;
    BlowerFanSpeed=map(ReefAngel.Params.Temp[1],775,800,25,100); // Calculate Blower Fan speed
    BlowerFanSpeed=constrain(BlowerFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(2,BlowerFanSpeed);
------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    #define Constant      0
    #define Random1       1 // Lagoonal
    #define Random2       2 // Reef Crest
    #define ShortWave     3
    #define LongWave      4
    #define Smart_NTM     5 // Nutrient Transport Mode
    #define Smart_TSM     6 // Tidal Swell Mode
    #define Feeding_Start 7
    #define Feeding_Stop  8
    #define Night         9
    #define Slave_Start   97
    #define Slave_Stop    98
    #define None          99
    RF Mode      = http://YOURIPADDRESS:2000/mb855,X
    RF Speed     = http://YOURIPADDRESS:2000/mb856,X
    RF Duration  = http://YOURIPADDRESS:2000/mb857,X
//-------------------------------------------------------- Start RF Smart Nutrient Mode After Feeding ---------------------------
    if (vtechmode == 9)
      ReefAngel.RF.UseMemory=true;
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding)
      bFeeding=false;
      ReefAngel.Timer[1].SetInterval(600); // Timer for 10min
      ReefAngel.Timer[1].Start();
      ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Smart_NTM,200,6);
      vtechmode = 5;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[1].IsTriggered())
      vtechmode = 9;
//---------------------------------------------------------- End RF Smart Nutrient Mode After Feeding -----------------------------
    ReefAngel.Portal("mvwise");
//--------------------------------------------------------------- End Loop --------------------------------------------------------
projectx
Post by projectx »
I am having a problem using the new 1.0.1 lib, when pushing the pwmslopechannel0 i get no member errors in the validation and it wont push. I deleted the lib directory and reinstalled them over again with the same result.
Any ideas?
projectx
Post by projectx »
These are the exact errors I get
sketch_aug04b:82: error: 'class RA_PWMClass' has no member named 'Channel0PWMSlope'
sketch_aug04b:83: error: 'class RA_PWMClass' has no member named 'Channel1PWMSlope'
sketch_aug04b:84: error: 'class RA_PWMClass' has no member named 'Channel2PWMSlope'
sketch_aug04b:85: error: 'class RA_PWMClass' has no member named 'Channel3PWMSlope'
sketch_aug04b:86: error: 'class RA_PWMClass' has no member named 'Channel4PWMSlope'
sketch_aug04b:87: error: 'class RA_PWMClass' has no member named 'Channel5PWMSlope'
sketch_aug04b.cpp: In function 'void DrawCustomMain()':
sketch_aug04b:111: error: 'class RA_PWMClass' has no member named 'GetChannelValue'
Can I see your code?
projectx
Post by projectx »
Here you are,
I commented those lines out so I could get the controller back online
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.DosingPumpRepeat1( Port7 );
ReefAngel.DosingPumpRepeat2( Port8 );
ReefAngel.MoonLights( Box1_Port1 );
ReefAngel.MoonLights( Box1_Port2 );
ReefAngel.ActinicLights( Box1_Port5 );
ReefAngel.ActinicLights( Box1_Port6 );
//ReefAngel.PWM.Channel0PWMSlope();
//ReefAngel.PWM.Channel1PWMSlope();
//ReefAngel.PWM.Channel2PWMSlope();
//ReefAngel.PWM.Channel3PWMSlope();
//ReefAngel.PWM.Channel4PWMSlope();
//ReefAngel.PWM.Channel5PWMSlope();
ReefAngel.Portal( "projectx" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
// ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,x+24,y,ReefAngel.PWM.GetChannelValue(a) );
y += 10;
ReefAngel.LCD.DrawMonitor( 15, 38, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 38, ReefAngel.Params );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
I need to add more keywords on the auto-selection of features.
Here is what you do to fix for now.
Open the file feature.txt located at "Documents\Arduino\update\"
Add this line to the end of the file:
PWMEXPANSION,ReefAngel.PWM.Channel0,Dimming Expansion Module
projectx
Post by projectx »
OK will do
Silly question if I loaded it all into memory can I change the PWM slope via the portal and not have to worry about pushing the code?
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
Yes.
The way your code is, you will be able to do that :)
Just uncomment those lines and use the Internal Memory section of the Portal.
projectx
Post by projectx »
Ok now I have another issue. (if you want I can start a new thread on it)
My ATO keeps running and it does timeout but if when I clear the timeout it starts filling again.
On the portal I do not see the vortech setting, my PWM module is not changing %.
In the Droid app, the vortech is showing the wrong speed setting, I have it set to Reef Crest and its showing Constant, with 0 speed.
PWM is not showing any % either.
For the vortech, add this to setup():
ReefAngel.AddRFExpansion();
Is it displaying PWM% on your controller screen?
On android app, go to settings->settings and make sure that you uncheck "Pre v1.0 memory locations"
projectx
Post by projectx »
Add this to the INO file?
on the screen it is also showing nothing % wise.
yes in the app I verified that it was unchecked
Yes, add to setup().
Did you uncomment the line you had previously commented that would display the % on the screen?
projectx
Post by projectx »
Yes I removed the line of code.
Ill add the other line and report back
Thanks for your help as always
projectx
Post by projectx »
Added that line and same result with the Vortech on both the Portal as well as the App
for now it seems my ATO is working properly.
The PWM I will have to recheck tomorrow as it is past the time for the lights to be active.
When you compile, does it show it found the RF Expansion feature?
projectx
Post by projectx »
So the PWM is working ok now.
my ATO is still not working properly and here is the copy of the complile
avrdude: Recv: p [70]
avrdude: Recv: r [72]
avrdude: Recv: o [6f]
avrdude: Recv: j [6a]
avrdude: Recv: e [65]
avrdude: Recv: c [63]
avrdude: Recv: t [74]
avrdude: Recv: x [78]
avrdude: Recv: . [00]
avrdude: Recv: . [2e]
avrdude: Recv: 0 [30]
avrdude: Recv: m [6d]
avrdude: Recv: l [6c]
avrdude: Recv: h [68]
avrdude: Recv: . [0d]
avrdude: Recv: . [0a]
avrdude: Recv: G [47]
avrdude: Recv: E [45]
avrdude: Recv: T [54]
avrdude: Recv: [20]
avrdude: Recv: / [2f]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: w [77]
avrdude: Recv: i [69]
avrdude: Recv: f [66]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: b [62]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: a [61]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: v [76]
avrdude: Recv: [20]
avrdude: Recv: d [64]
avrdude: Recv: H [48]
avrdude: Recv: P [50]
avrdude: Recv: 1 [31]
avrdude: Recv: [20]
avrdude: Recv: s [73]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: < [3c]
avrdude: Recv: V [56]
avrdude: Recv: > [3e]
avrdude: Recv: R [52]
avrdude: Recv: M [4d]
avrdude: Recv: I [49]
avrdude: Recv: N [4e]
avrdude: Recv: O [4f]
avrdude: Recv: D [44]
avrdude: Recv: A [41]
avrdude: Recv: Y [59]
avrdude: Recv: C [43]
avrdude: Recv: n [6e]
avrdude: Recv: [20]
avrdude: Send: . [1b] - [2d] . [00] . [04] . [0e] . [14] . [01] . [00] [20] . [09]
avrdude: Recv: . [1b]
avrdude: Recv: - [2d]
avrdude: Recv: . [01]
avrdude: Recv: . [03]
avrdude: Recv: . [0e]
avrdude: Recv: . [14]
avrdude: Recv: k [6b]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: ^ [5e]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: ` [60]
avrdude: Recv: [20]
avrdude: Recv: : [3a]
avrdude: Recv: 2 [32]
avrdude: Recv: 3 [33]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: g [67]
avrdude: Recv: W [57]
avrdude: Recv: S [53]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: & [26]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: F [46]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: [20]
avrdude: Recv: u [75]
avrdude: Recv: [20]
avrdude: Recv: = [3d]
avrdude: Recv: . [ff]
avrdude: Recv: , [2c]
avrdude: Recv: . [02]
avrdude: Recv: . [1c]
avrdude: Send: . [1b] . [2e] . [00] . [04] . [0e] . [14] . [00] b [62] [20] i [69]
avrdude: Recv: . [10]
avrdude: Recv: @ [40]
avrdude: Recv: . [f9]
avrdude: Recv: . [0f]
avrdude: Recv: . [17]
avrdude: Recv: ( [28]
avrdude: Recv: . [1f]
avrdude: Recv: . [1e]
avrdude: Recv: . [06]
avrdude: Recv: . [0c]
avrdude: Recv: . [12]
avrdude: Recv: . [18]
avrdude: Recv: . [d8]
avrdude: Recv: . [05]
avrdude: Recv: . [86]
avrdude: Recv: . [ea]
avrdude: Recv: . [1a]
avrdude: Recv: K [4b]
avrdude: Recv: + [2b]
avrdude: Recv: . [11]
# | 100% 14.73s
avrdude: verifying ...
avrdude: 36450 bytes of flash verified
avrdude: Send: . [1b] / [2f] . [00] . [03] . [0e] . [11] . [01] . [01] ( [28]
avrdude: Recv: ) [29]
avrdude done. Thank you.
Oh, sorry...
Click Verify and paste the output.
projectx
Post by projectx »
No problem, but it doesnt look like it is recognizing it
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Relay Expansion Module
Simple Menu
Binary sketch size: 36,450 bytes (of a 258,048 byte maximum)
Sorry, just realized that we are missing that keyword in the features auto-selection feature.
So, for now, add this commented line to anywhere your code
//ReefAngel.RF.UseMemory=true;
projectx
Post by projectx »
I think we delt with that the last update lol, so much for learning from my mistakes
what about the ATO Issue, I have it setup in the code as a standardATO, I checked the switch and it is good, goes open when all the way up and closes when down.
StandardATO uses 2 float switches.
http://forum.reefangel.com/viewtopic.php?f=7&t=240
Are you using both? One facing up and one facing down?
projectx
Post by projectx »
Ah no shoot I am my own worst enemy I am using 1 switch
Sent from my Galaxy Nexus using Tapatalk 2
projectx
Post by projectx »
Thanks for your help, I am back to 100% now.
I need to setup my original INO side-by-side with the new one next time.
also added this in //ReefAngel.RF.SetMode(); and the vortech now shows up on the portal
