feed timer
Thavngr98
feed timer
Can someone write me the code to daily
Turn feed mode on at 7:55
Turn feed mode off (turn everything back on) at 8:15
Turn feed mode on at 18:55
Turn feed mode off (turn everything back on) at 19:15
-Dave
Re: feed timer
Try this:
ReefAngel.Init();
ReefAngel.Timer[FEEDING_TIMER].SetInterval(1200);
ReefAngel.Relay.On(Port8);
if(hour()==7 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
if(hour()==18 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
Thavngr98
Re: feed timer
That's fine.
Just change this:
To this:
Just change this:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
Thavngr98
Re: feed timer
Yes, but make sure you merge the two sections of the 3 custom sections.
The 1st section is for global variables declaration, which we did not use in this code.
The 2nd section is inside the setup() function and deals with initializing stuff and only happens once, which would be this:
And the 3rd is the section inside loop(), which is stuff the controller will do stuff and monitor, which would be this:
Re: feed timer
BTW, there is no harm if you placed everything in the 3rd section too...
You could have done that. The controller will do just the same thing in this case. Just for the point of view of code organization is we prefer to place the stuff where they should be and not simply bunch everything up in the same spot.
kimacom
Re: feed timer
Great post.
i was looking for it.
thank you guys.
Tim
thank you guys.
Tim
