Actinics not intensifying at night
				Seagals
			Hey all, looking for some help - I have the RA+ and i am using the RA wizard but I am having some issues on the ramp down lighting.  It seem that the actinics are not getting bluer or the whites are not turning down at night.  It seems like the color stays constant all day.  I have confirmed the blues and whites are on.
Any advice is appreciated, thanks
The code is as follows:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port2,8,30,21,0 );
ReefAngel.StandardLights( Port3,9,0,21,30 );
ReefAngel.StandardLights( Port4,9,0,21,20 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,21,30,5,40,60,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,80,60,35) );
ReefAngel.Portal( "Seagals" );
Re: Actinics not intensifying at night
Not sure what you mean.
It's not supposed to change. They ramp up within 60 minutes and stay flat all throughout the day and ramp down in the last 60 minutes. Is it not what you want?
						- DrewPalmer04
I think he wants the PWMParabola effect
				Seagals
rimai wrote:Not sure what you mean.
Correct it does not seem to be ramping down at night.
				Seagals
I dont have a line for 'lighting' on the RA screen.rimai wrote:Does it show going down on the RA screen?
It should show AP: Actinics PWM and DP: Daylight PWM.
				Seagals
I dont have any thing that mentions lighting or Actinics, etc; here is what the main screen says:
Main:
feeding
water change
ATO clear
overheat clear
ph calibration
sate/time
version
exit
Any thoughts on ho to fix??
						Main:
feeding
water change
ATO clear
overheat clear
ph calibration
sate/time
version
exit
On the main screen, you should have T1, T2, T3, pH, AP and DP.
AP and DP are the PWM % of your dimming channels.
				Seagals
opps, yes i do have the ap% and dp 35%
What do you think
						What do you think
It means that it is at 35%.
It's past 9:30pm, right?
That's what you have setup. To go to 35% after light period.
Is there a reason why you setup that way?
				Seagals
no,no reason - if thats the case its by mistake, after 9:30 all should be off.
How do i correct?
						How do i correct?
These are the 2 lines that control your dimming channels:
The PWMSlope parameters are as follow:
Hour on
Minute on
Hour off
Minute off
start %
end %
duration
default %
The last one is the % you want to have when the lights are off.
Most people use 0% or the same as end %.
So, I think what you want to do is this:
Hour on
Minute on
Hour off
Minute off
start %
end %
duration
default %
 ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,5,80,60,5) );
				Seagals
ok, I will Revise and check on it tomorrow.
Thank you!!!!
						Thank you!!!!
				Seagals
Thank you!!!!
						Thank you!!!!
