Adding to code
dtzreef
Adding to code
So, this is the code I am running now:
byte wmport=Port5;
boolean wmdelay=false;
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "DTZ REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 118, 119, 118);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Main Tank:");
char text[7];
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 88, 15, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 46, "pH:");
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 46, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,25,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 88, 25, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,36,"Refugium:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 88, 36, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 38, 57,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,105,64,t);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO(Port1,240);
ReefAngel.StandardLights(Port3,10,0,22,0);
ReefAngel.StandardLights(Port4,11,0,21,0);
ReefAngel.StandardHeater(Port7,770,790);
//wavemaker timers and slow down at night
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6;
else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
ReefAngel.Portal("dtzreef");
I would like to add "Lights On" and "Lights Off" mode to the menu and a 5 minute delay on Port #2 (skimmer) after water change and feeding mode. I know it has something to do with RAGen, but I just cannot figure out how to add these features. Everything else has worked out great, I just need a little tweaking. Please help.
byte wmport=Port5;
char text[7];
if (t>=0)
if (wmdelay)
else wmport=Port5;
wmdelay=false;
wmdelay=true;
dtzreef
Re: Adding to code
I forgot I need to add "Set Date/Time" to Menu......
Re: Adding to code
Try this:
byte wmport=Port5;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Lights On";
prog_char menu7_label[] PROGMEM = "Lights Off";
prog_char menu8_label[] PROGMEM = "Date/Time";
prog_char menu9_label[] PROGMEM = "Version";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label, menu9_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
void MenuEntry8()
ReefAngel.SetupDateTime();
void MenuEntry9()
ReefAngel.DisplayVersion();
char text[7];
if (t>=0)
if (wmdelay)
else wmport=Port5;
wmdelay=false;
wmdelay=true;
dtzreef
Re: Adding to code
BAM!!! You are great!!!
Except, the Lights On/Off doesn't work and the Skimmer (port #2) does not turn back on after waterchange mode.
dtzreef
Re: Adding to code
Controller is showing port #2 on. But it is not.
dtzreef
Re: Adding to code
Check last!!!! Skimmer does work, it was the pump......duh
Re: Adding to code
I tested the code and I can make port 3 and 4 turn on when you choose lights on and they turn off when you hit lights off.
dtzreef
Re: Adding to code
Ok. I'll give it another try in the morning. What part in the code controls the lights on/off? I really want to learn to code it myself someday. Thanks again
Re: Adding to code
void MenuEntry6()
#ifdef RelayExp
#endif // RelayExp
void MenuEntry7()
#ifdef RelayExp
#endif // RelayExp
dtzreef
Re: Adding to code
Got it. Worked from the beginning, it just doesn't turn the lights off when they are on during the day, just on/ off at night. Can lights on/ off during the day be coded as well? I hope this makes sense.
Re: Adding to code
Try this one:
byte wmport=Port5;
prog_char menu8_label[] PROGMEM = "Lights Auto";
prog_char menu9_label[] PROGMEM = "Date/Time";
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
void MenuEntry5()
void MenuEntry6()
ReefAngel.Relay.RelayMaskOff = 255;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff = ~ReefAngel.LightsOnPorts;
void MenuEntry8()
void MenuEntry9()
char text[7];
if (t>=0)
if (wmdelay)
else wmport=Port5;
wmdelay=false;
wmdelay=true;
dtzreef
Re: Adding to code
Thanks so much Roberto!! Now, is there a code to have it make breakfast in the morning;)
Adding to code
You could use an expansion relay box to turn on the coffee machine and the toaster...
