ReefAngel Generator Installer is located here for downloading:
https://github.com/curtbinder/RAGen/downloads
The latest version is usually at the top of the Downloads section. The installer is bundled with my Development libraries as well.
The filename of the installer will include:
- ReefAngel Generator Version
- Development Library Version
So make sure you grab the latest version when downloading and look at the filename to make sure.
NOTE: You do not need to install the VC++ 2005 Redistributable Libraries if you use the installer. The files get automatically installed for you.
Curt
