Thavngr98
Posts: 83 Joined: Sun Jul 29, 2012 6:47 pm
Post
by Thavngr98 » Fri Sep 14, 2012 5:50 pm
So I used the wizard to setup up my relay box but when I load the code to Audrino I dont see any of it. Is that when written to memory that its not listed in the code? What im trying to do is lessen the timer on my Refugium light right now with the wizard it only lets you do On Opposite of Daylight and Blues. For me this is too long of a period for the refugium light to come stay on. Can you supply a custom code so that outlet 4 goes on at 3am and goes off at 9am?
Here is my current code
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port8Bit;
ReefAngel.AddDateTimeMenu();
ReefAngel.Timer[FEEDING_TIMER].SetInterval(950);
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.StandardATO( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.ActinicLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.StandardFan( Port7 );
if(hour()==7 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
if(hour()==18 && minute()==55 && second()==0) ReefAngel.FeedingModeStart();
ReefAngel.Portal( "thavngr98" );
-Dave
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Fri Sep 14, 2012 5:58 pm
Which port is it?
Thavngr98
Post
by Thavngr98 » Fri Sep 14, 2012 6:02 pm
port 4
-Dave
Post
by rimai » Fri Sep 14, 2012 6:23 pm
Replace this:
With this:
ReefAngel.StandardLights( Port4,9,0,20,0 );
Thavngr98
Post
by Thavngr98 » Sat Sep 15, 2012 6:28 am
That didnt work. I just uploaded the new code and its 9:30 am here and the light on port 4 is on
-Dave
Post
by rimai » Sat Sep 15, 2012 8:29 am
You need to change the time settings on the function.
I don't know what time you wanted, so I just put any number.
In fact, it turns on at 9:00am and off at 8:00pm
alexwbush
Posts: 327 Joined: Tue Mar 22, 2011 12:45 am
Post
by alexwbush » Sat Sep 15, 2012 9:44 am
You need to change it to:
ReefAngel.StandardLights( Port4,A,B,C,D );
Where...
A is the turn on hour (0-23)
B is the turn on minute (0-59)
C is the turn off hour (0-23)
D is the turn off minute (0-59)
All times are military times 0:00-23:59
So if you wanted to turn on 8:30pm-6:15am:
ReefAngel.StandardLights( Port4,20,30,6,15 );
Thavngr98
Post
by Thavngr98 » Sat Sep 15, 2012 9:58 am
LOL ok I just assumed it was correct since I posed the time in the original post. No problem Ill give it a shot
-Dave
