Need some assistance here. Brand New controller just opened the box today
here is the error I am getting
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 4,768 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\riggeek\AppData\Local\Temp\build6744928648949724390.tmp\sketch_sep15b.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM4
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
I have selected Reef angle plus controller, on COM 4 (verified on device manager), tried the serial manager and it did make the controller reboot.
here are some photos of the cable hook up. I did notice the the wire color sequence of the cable on the plug does not match the color sequence of the reef angel manual.
error uploading
error uploading
- IMAG0052.jpg (300.18 KiB) Viewed 3203 times
- IMAG0051.jpg (584.76 KiB) Viewed 3203 times
riggeek
Re: error uploading
Yes, it does look like the yellow and orange are inverted in your cable.
Would you be able to switch them?
