change ATO timeout
Thavngr98
change ATO timeout
is there a custom code I can add to change the ATO time out rather then use the wizard everytime?
-Dave
Thavngr98
Re: change ATO timeout
ntw I want to set it to 30 min. For some reason when i set it in the wizard it ends up going back to the default 60 sec after I load the new code
-Dave
alexwbush
or if you run the android app, you can change it on the fly and adapt it to suit your needs are you zero in the right time
