Hi all,
Timer is off by 3hrs. How do I change it?
I added this code
ReefAngel.AddDateTimeMenu(); // added control 09/16/12
When I toggle to change time and click OK, the main menu reverts back to old time
How to change Date/Time
Re: How to change Date/Time
If you unplug from wall to remove power and power it back up, what happens to the time?
stays the same. Seems like it's on PST instead of EST.
Are you sure that you are choosing OK after you change the time??
shit, that was it. Very hard to distinguish when cursor has cancel or ok selected.
Anyway to change contrast?
next library update you will be able to use the custom colors again.
Thanks Roberto.
