Trouble uploading from wizord
Talk about you and your tank/equipment
Gideon1
Post by Gideon1 »
My controler won't update from wizord. I was given a patch to fix repeat dosing problem and tried to generate and upload codes but keep getting error. Here is what i'm trying to do but i get error on bottom of wizord that I can't copy (don't know where clipbord is) wont copy and paste, the normal way. Hope someone can help me, it's been like 4-hours all that's on in tank is my heater pluged into the wall :|
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port2,21,30,10,0 );
ReefAngel.StandardLights( Port3,10,0,21,30 );
ReefAngel.StandardLights( Port4,10,30,21,30 );
ReefAngel.StandardHeater( Port6,787,815 );
ReefAngel.DosingPumpRepeat( Port7,420,1440,20 );
ReefAngel.DosingPumpRepeat( Port8,425,1440,20 );
Re: Trouble uploading from wizord
Code compiles file here.
It must be the file you are using.
Try the attached one.
ReefAngel.cpp
(134.47 KiB) Downloaded 682 times
Gideon1
Post by Gideon1 »
Thanks for getting back with me....but this still is not working...can you log in and see for your self?
sure, pm me the id
For your reference in the future, here is a link that has the shortcut keys for copy and paste:
http://wiki.answers.com/Q/What_are_hot_ ... plications
