Jon
Try adding this to your setup:Code: Select all
ReefAngel.Timer[FEEDING_TIMER].SetInterval(900);
//Fast feeder timer
#define FastFeed 105
byte Feed = 0;
if ((hour() >= 10) || (hour() <= 19)) //from 10a-7p
if (minute() ==30 && second() == 0) //once an hour on the half hour
Feed = 1; // Turn on feeder and feedmode
ReefAngel.Timer[FEEDING_TIMER].SetInterval(InternalMemory.read(FastFeed));
ReefAngel.FeedingModeStart();
ReefAngel.Timer[FEEDING_TIMER].SetInterval(InternalMemory.FeedingTimer_read());
Feed = 0;
ReefAngel.Timer[FEEDING_TIMER].Start();
You are correct. It should not affect the current timer at all. The reason I say this is because of how Start() works. When you call Start(), it computes the end value (aka, Trigger value). Every time you call the function IsTriggered() to determine if the timer is expired/triggered, it just checks the current time against the end time. It never looks at the interval until Start() is called.rimai wrote:I'm not 100% sure, but I think it would not affect the current timer until it resets again or you use the function I posted.
#define FastFeed 105 //Fast feeder timer
byte Feed = 0;
// Custom Menu Code
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "pH Calibration";
prog_char menu4_label[] PROGMEM = "pH Detail";
prog_char menu5_label[] PROGMEM = "Temp Detail";
prog_char menu6_label[] PROGMEM = "AutoFeed";
prog_char menu7_label[] PROGMEM = "Flow Cells";
prog_char menu8_label[] PROGMEM = "Version";
prog_char menu9_label[] PROGMEM = "Sound Bytes";
menu4_label, menu5_label, menu6_label,
menu7_label, menu8_label, menu9_label
void MenuEntry6() //Autofeeder manual trigger
Feed = 1;
//Autofeeder Mode
if ( InternalMemory.read(VacationEnable) <= 2 ) // check for vacation mode
// Check if the current time is equal to the start time.
if (NumMins(hour(), minute()) == (NumMins(InternalMemory.read(VacationStartHr), InternalMemory.read(VacationStartMin))))
if (second() == 0)
else Feed = 0;
if ( InternalMemory.read(VacationEnable) == 2 ) // check for vacation mode
if (NumMins(hour(), minute()) == (NumMins(InternalMemory.read(VacationStart2ndHr), InternalMemory.read(VacationStart2ndMin))))
if (second() == 0)
else Feed = 0;
if ( InternalMemory.read(VacationEnable) == 3 ) // check for vacation mode
else Feed = 0;
...Code: Select all
byte Feed = 0;
byte AutoFeed = 0;
// Custom Menu Code
AutoFeed = 1;
Feed = 1;
AutoFeed = 0;
//Autofeeder Mode
if ( InternalMemory.read(VacationEnable) <= 2 && Autofeed == 0) // check for vacation mode
if (second() == 0)
else Feed = 0;
if ( InternalMemory.read(VacationEnable) == 2 && Autofeed == 0) // check for vacation mode
if (second() == 0)
else Feed = 0;
if ( InternalMemory.read(VacationEnable) == 3 && Autofeed == 0) // check for vacation mode
else Feed = 0;
