Start unit without ph probe attached?
Hello, Bran Newbe. Quick question. Just rcvd My RA. Want to start it up. Can I start the unit without the Ph probe plugged in? Just want to start it up. Look at temp. Play around for a while...... I have no Ph buffer. Or should I plug it in but not remove from shipping solution? Thanks
Re: Start unit without ph probe attached?
wow thanks Roberto. I'm excited....
Heres what I have.power to relay unit. cable fm relay to controller attached. Temp probe connected. Controller screen shows blank graph. T1 temp 76.5 Ph 8.51 T2 error DP17. T3 error ap18. shows 8 relay status lights red or green with various relays turning off and on. Joy stick has no effect on screen.
Everything looks good.
If you want to know more about the preloaded code, download the user manual.
Press the joystick to access the menu.
The Joy stick doesn't move the screen...
Last edited by scootscomputes on Tue Oct 09, 2012 5:05 pm, edited 1 time in total.
There is nothing to move. There is only one screen.
If you press it, you can access the menu.
Ok Press it down. I was moving it in the down direction. Sry
