Heater code
dbmet
Heater code
Post by dbmet »
I would like the Heater outlet to be on and the let the heater control the temperature but have a failsafe to turn off the outlet if something goes wrong with the heater..
I have this so far but not sure what to put for the outlet
ReefAngel.OverheatShutoffPorts = Port4Bit;
Re: Heater code
Use it always on.
dbmet
Re: Heater code
Post by dbmet »
Got it..
alexwbush
Re: Heater code
Post by alexwbush »
just curious, what heater are you using? You think it'd be more accurate than a controller controlling the temperature?
With the controller controlling the relay for heater, you could also see when the heater is on and off throughout a time period using the portal.
dbmet
Re: Heater code
Post by dbmet »
Not even sure the model heater I have.. Has a temp display and all that... but I decided to Let the controller do it anyway and also put in the overtemp code just in case..
