Help???
Here's my code
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define wifi
#define RelayExp
#define InstalledRelayExpansionModules 1
#define SIMPLE_MENU
#define CUSTOM_MAIN
ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params);
ReefAngel.LCD.DrawOutletBox(12, 92, TempRelay);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.FeedingModePortsE[0] = Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port2Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On(Port6); //CO2 solenoid
ReefAngel.Relay.On(Port2); //broken port, stuck on
ReefAngel.Relay.On(Box1_Port3); //CA reactor PH monitor
ReefAngel.Relay.On(Box1_Port4); //CA reactor recirculation pump
ReefAngel.Relay.On(Box1_Port5); //Feed pump for media reactor
ReefAngel.Relay.On(Box1_Port6); //Return
ReefAngel.Relay.On(Box1_Port7); //Skimmer
ReefAngel.Relay.On(Box1_Port8); //broken port, stuck on
// Specific functions
ReefAngel.MHLights(Port1,17,30,01,00,15); //MH light schedule, on at 530PM, off at 1:00AM
ReefAngel.StandardLights(Box1_Port2,17,30,01,00); //broken port, stuck on, T5 Main, on at 530PM off at 1:00AM
ReefAngel.StandardLights(Port3,17,00,01,30); //T5 actinic, on at 5:00PM off at 01:30AM
ReefAngel.StandardLights(Port4,13,00,17,30); //LED night, on at 1:00PM, off at 530PM
ReefAngel.StandardLights(Port5,02,00,12,00); //Sump LED, on at 2AM, off at 12PM
ReefAngel.StandardHeater(Port7,750,754); //Heater, on at 75, off at 76
ReefAngel.StandardFan(Port8,770,774); //Exhaust Fan, on at 77.4, off at 77
ReefAngel.DosingPumpRepeat(Box1_Port1,00,30,60); //Dosing pump #1 - KALK, every half hour for 30 seconds
ReefAngel.Portal("estanoche", "password");
