For some reason Client 2.2 would not respond to listener etc. Would just not connect. So shut it down for awhile. When I restarted, shut and restarted the lsitener and logger service it finally reconnected. Surprising thing was the logs were still up to date, so even though the pc interface was not working the listener and logger services were still collecting data from the controller.
Not sure what happened with the interface there, but glad you got it working again. Did you see the 2:00 reconnect timer counting down on the bottom status bar?
That's one of the nice things about having the Listener/Logger as Windows services. If you leave them on automatic - then as soon as you computer boots up it will begin collection and logging data. No Client required
Yes, reconnect timer would count down, but would not reconnect. Who knows what it was, just prior I was removing some programs and doing some clean up of the computer. just one of those things. Impressed that it keeps the logging going. Means it's not necessary to keep the client interface running, until needed.
