Temp 1 stuck on and high
dnastynice
Post by dnastynice »
well i got every thing going and used the set up wizard. But im having an issue with the first temp probe slot or T1 as it is labeled. T2 and T3 all work fine. I tried to change temp probes and see if it was a bad probe that was causing the high temp reading, its not a bad probe. Its reading 91+ degrees and the other two are both in range of the separate. i know you must reboot to get the temp to recognize the probe. I have multiple times regenerated the code and reloaded it to the reef angle. Even with the temp probe not plugged in it reads 91+ degrees and even after multiple reboots with the wizard. Ive tried all that i can think of. im not to good with writing/reading code well i have no idea how to write/read it. :D here is my code if it helps. I am very good at deleting and copy and pasting :lol:
thanks for your help
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit;
InternalMemory.OverheatTemp_write( 821 );
ReefAngel.StandardLights( Port1,12,0,21,0 );
ReefAngel.StandardLights( Port2,13,30,19,0 );
ReefAngel.StandardHeater( Port3,759,770 );
ReefAngel.StandardFan( Port4,776,788 );
ReefAngel.StandardLights( Port5,20,45,12,4 );
ReefAngel.StandardLights( Port7,20,59,11,59 );
Re: Temp 1 stuck on and high
I don't think it is code related.
Here is what I'd like you to do.
Leave just on probe in the controller and reboot.
It will always read as T1. Don't worry. Write down the temperature.
Now, disconnect this probe and plug another one. Write down the temperature.
Disconnect the 2nd probe and plug the last probe. Write down the temperature.
Is there a single probe that has the wrong temperature?
dnastynice
testing now ill get back to you thanks for the fast response
dnastynice
ok i thinking its a bad probe after testing... does the controller know what probe is T1 T2 T3?? even moving them around they stay the same? crazy that it recognizes them some way i am thinking. 2 of the probes are with in .2 of each other but on is in the sump and ones in the main tank. the one probe that no matter what slot its plugged into says 91.0 degrees or more. can i calibrate the temp probe some how?
Yeah, I think you got a bad probe.
PM me to get a RMA number
dnastynice
PM sent thanks 8)
