wavemaker not fuction
marco3020
Post by marco3020 »
Good evening to all I have this problem the WaveMaker I do not work, I put the loaded code you give me a hand to understand thanks
Re: wavemaker not fuction
That code does not have wavemaker
marco3020
Post by marco3020 »
thanks for the reply how can I put the code to control it I WaveMaker from reef angel?
I WaveMaker menu but if I change my settings wrong coem should I do?
Have you tried using the Wizard?
Go to menu Tools->Reef Angel Wizard
marco3020
Post by marco3020 »
Tomorrow I try and tell you, but I have to do with angel client suite?
no, on arduino.
marco3020
Post by marco3020 »
I say if you explain to c / documents etc. or where? I do not understand
I didn't understand what you said. Sorry.
But, just open Arduino and go to menu Tools->Reef Angel Wizard.
http://forum.reefangel.com/viewtopic.php?f=8&t=1297
marco3020
Post by marco3020 »
hello roberto I saw the post but I have not figured out how to install the wizard apple explain that? and maybe send me the latest version thanks
dbmet
Post by dbmet »
What kind of computer do you have?
marco3020
Post by marco3020 »
windows 7
dbmet
Post by dbmet »
Go here and download windows installer http://www.reefangel.com/download.aspx
Then install it.. Then follow directions just open Arduino and go to menu Tools->Reef Angel Wizard
marco3020
Post by marco3020 »
i have istalled this, dont see reef angel wizard
marco3020
Post by marco3020 »
barbianj
Post by barbianj »
Like Roberto said, open the Arduino program, at the top left, click on tools, then scroll down to Reef Angel Wizard, and click on that.
dbmet
Post by dbmet »
Heres a picture--- Just ignore that I'm on a Mac
marco3020
Post by marco3020 »
good morrning i have this
http://imageshack.us/photo/my-images/713/wharis.png/
wharis reef angel wizard?
Did you change the place where your sketches are located under file->preferences?
marco3020
Post by marco3020 »
good evening to all I finally managed to find the reef angel wizard and set the WaveMaker, now I have another problem I can not understand the parable that is dimming and night, etc., how do I put sunrise and sunset as before? in short blue light first and then slowly raise the white and then the lights slowly during the day?
The parabola does that automatically.
marco3020
Post by marco3020 »
grazie di avermi risposto quindi non devo marcare la parabola ma solo opzione prima? tpo metterla da 10 a 100% in poco tempo, e come faccio a impostare prima i blu si accendono piano e poi i bianchi dopo tipo 10 minuti?
