I got my led lights hooked up to the relay expansion box. I can dim them using the iphone app. However I was expecting that when they turned on they would slowly ramp up the intensity however they just stay at whatever I set them to earlier..
Heres my code
#define Fan 8
#define LightWhite 7
#define Main Pump 6
#define Skimmer 5
#define Heater 4
#define Powerhead 3
#define ATO 2
#define LightBlue 1
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
#define CUSTOM_VARIABLES
byte x = 6;
byte y = 2;
byte t;
char text[8];
// Parameters
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,12,16,"Daryls 90 Reef",
Font8x8);
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
ReefAngel.LCD.DrawText(COLOR_RED,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(COLOR_RED,255,10,30,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_PURPLE, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
ReefAngel.LCD.DrawText(0,255,8,100, "WLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119,
ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "BLED");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119,
ReefAngel.PWM.GetActinicValue());
ReefAngel.AddStandardMenu();
ReefAngel.FeedingModePorts = Port3Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit;
InternalMemory.ATOExtendedTimeout_write(120);
ReefAngel.Relay.On( Port3 );
ReefAngel.ActinicLights( LightBlue );
ReefAngel.SingleATOLow( Port2 );
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off (Port2);
ReefAngel.StandardLights( LightWhite );
ReefAngel.StandardFan( Port8 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.Relay.DelayedOn( Port5 );
ReefAngel.Portal( "dbmet");
Led<-- Fixed and now to get clouds and lightning working
dbmet
Re: Led
Before you do that, please check if your memory settings are correct.
Memory locations 249-254
#define Mem_B_PWMSlopeStartD VarsStart+49
#define Mem_B_PWMSlopeEndD VarsStart+50
#define Mem_B_PWMSlopeDurationD VarsStart+51
#define Mem_B_PWMSlopeStartA VarsStart+52
#define Mem_B_PWMSlopeEndA VarsStart+53
#define Mem_B_PWMSlopeDurationA VarsStart+54
dbmet
Re: Led<---Fixed now to get clouds and lightning working
Dimming works beautifully..
Will I be able to use the tutorial for the clouds and lightening if I'm using the internal memory now?
http://forum.reefangel.com/viewtopic.php?f=14&t=288
