MoonPhase
dtzreef
MoonPhase
Post by dtzreef »
Hi everyone, Just to clarify a few things, I just set up my wifi and I have a slow blinking green light and I can see my params on the Portal, am I good? I thought I read somewhere that I should get a solid green light. Also I have two moon lights attached to the PWM channels with "moonphase" set in my code, do the moon lights follow some sort of pattern (phase)? When I pull up the portal i get different pwm % almost everytime. Is this correct?
Re: MoonPhase
slow blinking is good.
Can you post the code?
dtzreef
Re: MoonPhase
Post by dtzreef »
I will when I get home tonight. At work today. Yes, I am on Reef Angel at work ;) What can ya do?
dtzreef
Re: MoonPhase
Post by dtzreef »
Hey Roberto, here is the code I am running. Now I am having another problem, It seems as though my wifi is timing out or something. When I log into Portal it shows "unreachable Address". I thought I finally did something right without your help but, here I am again, at your mercy. So, as you are dissecting my code, would you find what I did wrong with the moonphase and wifi. Thank you so much!!!
Dave
byte wmport=Port5;
boolean wmdelay=false;
#include <avr/pgmspace.h>
prog_char menu1_label[] PROGMEM = "Feeding";
prog_char menu3_label[] PROGMEM = "ATO Clear";
prog_char menu4_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "PH Calibration";
prog_char menu6_label[] PROGMEM = "Lights On";
prog_char menu7_label[] PROGMEM = "Lights Off";
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = ReefAngel.LightsOnPortsE;
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = 0;
#endif // RelayExp
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "DTZ REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 118, 119, 118);
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Main Tank:");
char text[7];
ReefAngel.LCD.DrawText(COLOR_GOLDENROD, DefaultBGColor, 88, 15, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 50, 46, "pH:");
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 88, 46, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,25,"Room Temp:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 88, 25, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,8,36,"Refugium:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 88, 36, 10);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 38, 57,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 49, 67," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,105,64,t);
// ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
randomSeed(analogRead(0));
ReefAngel.Timer[1].SetInterval(random(30,45));
ReefAngel.Timer[1].Start();
InternalMemory.OverheatTemp_write( 805 );
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port8);
// Specific functions
ReefAngel.StandardATO( Port1,600 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardLights( Port3,9,0,21,0 );
ReefAngel.StandardLights( Port4,10,0,20,0 );
ReefAngel.StandardHeater( Port7,770,790 );
//wavemaker timers and slow down at night
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6;
else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
ReefAngel.Portal("dtzreef");
ReefAngel.LCD.BacklightOn();
Re: MoonPhase
You code looks good. Why do you think there is something wrong?
The moonphase for today is 31%. Isn't it what it is showing on screen for you?
It changes daily to follow the moon cycle.
Did you try removing the wifi and replugging it?
dtzreef
Re: MoonPhase
Post by dtzreef »
Great!!! So the moonphase does change daily. Cool. I will try the wifi thing. Thanks again!
dtzreef
Re: MoonPhase
Post by dtzreef »
Well, wifi is up and running. Thank you again! (I'm sure not the last time). Have a great night.
