2.2 Load Memory File
Bryan
Post by Bryan »
Wondering about the "Load Memory file" feature. Where does one get the memory file from. Don't see RA Gen creating one, unless it's the generated PDE.
-=Bryan=-
Re: 2.2 Load Memory File
Bryan wrote:Wondering about the "Load Memory file" feature. Where does one get the memory file from. Don't see RA Gen creating one, unless it's the generated PDE.
I haven't used 2.2 yet, but from talking with Dave about some of the features, I think this has to do with a memory map file. You have the ability to change the memory locations around IF I ever changed them on the controller. This would ensure that the client would write the values to the proper spot.
So I'm thinking this is what / how you would do it. If not, then I don't know what this option is for.
Bryan
Post by Bryan »
I thought perhaps it was to reload the Memory settings if one flashes the controller and erases the EEPROM. Would be handy rather than having to re-populate all the fields etc.
-=Bryan=-
dmolton
Post by dmolton »
binder wrote:I haven't used 2.2 yet, but from talking with Dave about some of the features, I think this has to do with a memory map file. You have the ability to change the memory locations around IF I ever changed them on the controller. This would ensure that the client would write the values to the proper spot.
This is indeed the intended purpose of the function.
Bryan wrote:I thought perhaps it was to reload the Memory settings if one flashes the controller and erases the EEPROM. Would be handy rather than having to re-populate all the fields etc.
It would be. Haven't figured out how to compile/upload to the controller from .NET yet.. Still relying heavily on the dev libraries and #define wifi for all communication with the controller.
