eds wrote:Im loving this app, it is the main app I use to control my tank
I had a thought about a feature, When I go away, I setup an IP cam to remotely check the tank if it alarms.
It would be awesome if there was a way to have the live video in one of the screens of this app so I can swipe to it. Not sure if its worth the effort but I thought it might be neat
i can look into displaying a live internet video feed inside the app but i can't promise anything. it may not be worth it and you may have better luck using another app for this.
symon_say wrote:This app is getting better and better, is so nice i don't remember the last time i check the screen on the controller.
Can you make the app select connection automatically depending on the data, lets say home for wifi and away for data network, this way the app will be updated always.
i have been thinking about doing something like this already. my initial thought was to switch profiles based on gps location. You would set your home location and as long as you were there it would use the home profile. then when you left the area it would automatically switch to the away profile.
i also have thought about switching based on whether wifi was on and connected to your home network (you specify the wifi network name for your network). that would be the home profile and if wifi was off or not connected to your network, it would be the away profile.
so there are several ways this could be handled and i can see some problems with each of them. i am not sure what way would be best. i may just have to incorporate all of them and let the user decide which one to use.
