Heater masking itself off
barbianj
Post by barbianj »
Not sure where to post this, but since last Saturday, my heater will randomly be masked to off on my Android app. At first, I thought that I had accidentally swiped the button, but it has happened many times since. It was working fine previously, and I can't put a finger on what event might be triggering it. Any thoughts?
Re: Heater masking itself off
Could it be overheat flag?
Does the controller have a red status led?
barbianj
Post by barbianj »
The controller does have the red status led on, but I cleared that by pressing ATO clear. I didn't try overheat clear.
My tank water has been around 73-74 until today, so it could not have been over temp. I've been watching my phone for the mask and taking it off. Now it's finally at 75.3. It's set to turn on at 76.6 and off at 77.0.
I noticed something else odd. In the Portal, my daylight PWM is at 20%, but I'm not using that function, that I'm aware of.
Here's my code:
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardLights( Port2,6,0,23,0 );
ReefAngel.StandardLights( Port3,13,0,22,0 );
ReefAngel.StandardLights( Port4,14,0,18,0 );
ReefAngel.Wavemaker( Port5,6 );
ReefAngel.StandardHeater( Port7,766,770 );
if (ReefAngel.WaterLevel.GetLevel()<40 && ReefAngel.WaterLevel.GetLevel()>0) ReefAngel.Relay.On(Port1);
if (ReefAngel.WaterLevel.GetLevel()>45) ReefAngel.Relay.Off(Port1);
ReefAngel.Portal( "barbianj" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,66, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel() );
Are you using extension?
Change this:
With this:
Now, dip your T2 in the water.
Let's see what happens.
barbianj
Post by barbianj »
Yes, using extension, but it's not necessary. Wasn't quite long enough to make it to DT one floor above, so it's in the sump.
Changed code, uploaded, put T2 in water. Reads 76.1, same as T1, and heater is on.
barbianj
Post by barbianj »
So far the heater has been running with no issues. Have not seen the mask magically appear.
iiluisii
Post by iiluisii »
The same happen to me last night .
