Need some help PLEASE!!!
treetopflyn
This is a code I would like to use but I would also like to have the wavemaker ports shut down at 9:00pm and turn back on at 7:00am. I can't figure out how to do it with the wizard. This stuff is all new too me so if someone could just change the code below , so I can cut and past, I would be very grateful.
Kevin
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port1,180 );
ReefAngel.WavemakerRandom( Port5,60,220 );
ReefAngel.WavemakerRandom( Port6,60,220 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Portal( "treetopflyn" );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
Kevin
int x,y;
// Parameters
// pH Expansion
// Main Relay Box
// Relay Expansion
// Date and Time
Re: Need some help PLEASE!!!
Change this:
To this:
ReefAngel.WavemakerRandom( Port6,60,220 );Code: Select all
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
treetopflyn
Awesome!! Thank you very much
treetopflyn
For some reason I keep getting an error when I try to load this code
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Relay Expansion Module
PH Expansion Module
Simple Menu
Binary sketch size: 30,918 bytes (of a 32,256 byte maximum)
C:\Program Files\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\Janine\AppData\Local\Temp\build9011814347133553550.tmp\sketch_oct28b.cpp.hex:i
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
CODE
ReefAngel.StandardATO( Port1,60 );
ReefAngel.WavemakerRandom( Port5,30,90 );
ReefAngel.WavemakerRandom( Port6,30,90 );
int x,y;
// Parameters
// pH Expansion
// Main Relay Box
// Relay Expansion
// Date and Time
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
PH Expansion Module
Simple Menu
avrdude: Recv:
CODE
int x,y;
// Parameters
// pH Expansion
// Main Relay Box
// Relay Expansion
// Date and Time
Which RA do you have? Standard RA or RA+??
Are you sure it is COM4 that you use to communicate with the controller?
treetopflyn
RA
I am using the same port I have always used
treetopflyn
strange the 10th time I said download it finally took
treetopflyn
OK not for some reason. Port # 6 is not switching on. 5 is doing what it is supposed to but 6 is not coming on. I can turn it on remotely but it is not cycling.
Oh, sorry...
Change this:
To this:
Change this:
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
treetopflyn
damn it now it won't load again
treetopflyn
arghhhhhhhhhhhhh
avrdude: Recv: . [7f]
avrdude: stk500_getsync(): not in sync: resp=0x7f
- DrewPalmer04
deep breath and relax. There is a bit of a learning curve with the RA...BUT once you get past it...this unit is AMAZING!
Sometimes you need to plug/unplug the ttl cable and make sure too its on the correct pins...
treetopflyn
done that several times already
treetopflyn
Got it thanks again
