Water top off using solenoid
Ask in here.
rossbryant1956
Post by rossbryant1956 »
I want to insert a small solenoid valve in my 1/4" line coming from my rodi and control it from float valves in my sump connected to my I\O unit. The choices I have available from my RODI vendor include"
"Solenoid Valve 1/4" plastic, 24V DC"
"Solenoid Valve 1/4" plastic, 24V AC"
"Solenoid Valve 1/4" plastic, 110V AC"
Which one would work best for RA apps. Thx
Re: Water top off using solenoid
110VAC will let you connect to a relay port
