Hi!!! At last, i have in my hand the RA with Wifi atachment and i try set up first wifi atachment and second i try load my code using the Wizard.
I open wifi Utility, after select a serial port (3-16), clik conect and the wifi Utility show me "ERROR-please disconnect the RA wifi atachment from the USB-TTL cable and try again". ( at the wifi atachmen blink fast blue lignt and green)....
The second problem is tha RA head unit. I generated a new code with Wizard, after one week i try to UPLOAD the code and the RA generator show me again ERROR UPLOADING. Wat is the problem????
This is the code.
ReefAngel.WaterChangePorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
InternalMemory.OverheatTemp_write( 355 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,310,325 );
ReefAngel.MHLights( Port3,12,0,18,0,30 );
ReefAngel.MHLights( Port4,9,0,19,0,30 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,5 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port4 ) );
ReefAngel.PWM.SetDaylight( PWMParabola(9,0,20,30,0,100,0) );
ReefAngel.Portal( "baroutas" );
set up wifi Attachment and load my first code from wizard...
Re: set up wifi Attachment and load my first code from wizar
Make sure you select "Reef Angel Controller w/optiboot" under Tools->Board and maybe try any different serial port you may have.
Again the same.... At the end of loading write: avrdude : stk500_getsync (): not in sync: resp=0x64
It is posimbole the cable (USB-TTL) have problem?
OK!! Roberto it work with port 8, after a few try!!!!
Now i have the problem with wifi atachment. The wifi Atachment Utility show me "ERROR-please disconnect the RA wifi atachment from the USB-TTL cable and try again". ( at the wifi atachmen blink fast blue lignt and green)....
OK!!! Ihave set up the wifi atachmen , but still blinking the blue cable fast and did not conect with my router....
Do you have a router with WPS push-button capability?
The new wifi attachments come with that feature too. Much easier to connect
Ok! It works!!!!! Thanks Roberto!!!!!!
