Portal unreachable adress
I have an error on the portal ''unreachable adress'' and the iphone ''Unable to connect'' I configure the wifi with my router with DNS. The module blinking green and I have access to the temperature, ph and orp but I'm not able to set the relay or accessed in memory. Same thing with the iphone.
I dont have a 2 way comunication only read.
Thank Eric
Thank Eric
Osaka 40g with 55g sump
Radion, 2X Tunze 6045, Swc-160 mini cone
Sorry I do not know how? I assume that it's in the router configuration?Sebyte wrote:Have you setup port forwarding on your router?
Re: Portal unreachable adress
The manual for your router should have the instructions. If not Google your router type and port forwarding.
Also have a look at
http://en.wikipedia.org/wiki/Port_forwarding
Also have a look at
Some people have had luck using this site..
http://www.simpleportforwarding.com/
With a newer router, you may be able to log in and do it through the browser. Check that the router's firmware is up to date, also.
Thank you very much for your help, after several hours reading and trying, the portal works correctly.
It is only now around 10 am that everything works correctly.
One small thing is that the web banner does not seem to update.
If I change the name of the relay it's updated but not the data.
I think the problem comes from the portal ...
Have you any idea?
Have you any idea?
That means the controller is still not sending data to the server.
Check if you have the Portal() function in your code.
Which application did you use to configure the wifi attachment?
Everything works in the portal, I can activate ports (on/off) it's only the banner and the iphone app does not work.
I configured the wifi expansion with Dns button (wifi and router) for generated my code I use the wizard.
This is my code:
This is my code:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardLights( Port4,16,0,22,0 );
ReefAngel.DosingPumpRepeat( Port8,0,60,70 );
ReefAngel.Portal( "AquaO" );
int x,y;
// Parameters
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,66, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,66, ReefAngel.Params.ORP );
// Main Relay Box
// Date and Time
The portal has run well all day (turn on/off relay) and good data (temp,ph,orp), but now sometimes it disconnects and I have a unreachable adress and other times it's ok.
This is my setup:
Reef Angel wifi address: 70.82.xx.xx:2000
My virtual server:
Service Name Port Range Local IP Local Port Protocol
reefangel 2000:2000 192.168.1.2 2000 TCP
I used the WPS button for wifi/router and I use the wizard for the code
The banner and iphone app not work.
Thank you for your help
This is my setup:
My virtual server:
May I ask to use Dave's utility and pull the wifi settings?
You can download the utility on the contribution download page of the website.
yes I also try with wifi utility without success ... tell the truth it's been several days that I try several configurations.
I will ask a friend who knows the network to help me.
Thank you
Thank you
ok, can you post the results of "get e" command when you use Tera Term?
