WM off when lights off?
bigHUN
Post by bigHUN »
Just did the replacement, RA board to RA+, loaded the internal mem, and generated the first code with the Wizard...
I must say what an upgrade, I really like the job you folks did there.
My lights went OFF for first time, and than realized my WMs still running. I wen't through the wizard several times, just can't see the button where to turn the wavemakers off in the dark?
how this command shall look? and where to place? thanks
bigHUN
Re: WM off when lights off?
Post by bigHUN »
just realized this may not be a best idea...in next few days I will look for some nice thunderstorm effects here on forum, this may smoke my WMs very quickly, better me put on timer than?
let say turn on 30 minutes after first light on and turn off 30 minutes before last light off?
how this code shall look?
just set them up as timed ports just like lights.
bigHUN
Post by bigHUN »
first night over. in the morning I saw the skimmer was off overnight...
is this a default than?
- when lights off WMs ON and skimmer OFF ?
where can I see that setting?
I have 2 WMs, one big polario and one circulating pump to take care of............especially because on the closed loop there is one inline heater for case if the main pump goes psycho...
dbmet
Post by dbmet »
Can you post the code you uploaded to the ReefAngel from the Wizard?
bigHUN
Post by bigHUN »
RA+ controller, anyhow I can insert the timing through the GUI for wavemakers do not work at all when the lights are off? I don't know how to write it and where to insert below....
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 265 );
    ReefAngel.StandardATO( Port1,60 );
    ReefAngel.StandardHeater( Port2,240,255 );
    ReefAngel.StandardLights( Port3,9,0,19,0 );
    ReefAngel.StandardLights( Port4,11,0,17,0 );
    ReefAngel.Wavemaker( Port5,5 );
    ReefAngel.Wavemaker( Port6,6 );
    ReefAngel.Relay.DelayedOn( Port7,3 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,19,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(10,0,18,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(11,0,17,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(12,0,15,0,15,60,15) );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 39;
      ReefAngel.LCD.DrawCircleOutline( x+(a*20),y,4,COLOR_MEDIUMORCHID );
      if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE; else bkcolor=COLOR_GRAY;
      ReefAngel.LCD.FillCircle( x+(a*20),y,2,bkcolor );
    // Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
    ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Main Relay Box
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
    ReefAngel.LCD.DrawOutletBox( 12, 90, TempRelay );
    // Date and Time
Let me see if I understand.
You want the WM on port 5 and 6 to be off when lights on port 3 is off. Is it correct?
bigHUN
Post by bigHUN »
correct, can you show me one example how this shall look like: WM on when ligts on and off when .. off (either actinic or daylight)
also, can you give me a sample code: light on, WM delayed on + 20 minutes (after the lights comes on), WM advanced off -20 minutes from lights off (before the lights go off).
based on these two examples I shall be able to do several other things as well.
also, where to pleace the lines? between? // place your custom codes here //
thanks
Replace this:
With this:
if (hour()>=9 && hour()<20)
    ReefAngel.Relay.Set(Port6,ReefAngel.Relay.Status(Port5));
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
bigHUN
Post by bigHUN »
Roberto, many thanks.
btw, word by word what this line means?
[set the relay port6 when the status is.. what?...and what that means port5 in brackets?....]
will this conflict with WMs timing? or if I switch them in the future to alternate?
bigHUN
Post by bigHUN »
rimai wrote:Replace this:
With this:
I did the replace, right now the time is 9.03 pm, lights are off,
1.) both WM ports in the same time toggling on/off every 5 sec
2.) since sitting here in front of it, noticed the skimmer went off 8.59 pm, and came on 9.03
I don't see anything else in the code but the "delay 3 min" on port 7 ?????????????
#include <Wire.h>
#include <Time.h>
#include <RA_ATO.h>
#include <LED.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
    ReefAngel.StandardATO( Port1,62 );
    ReefAngel.StandardLights( Port3,8,55,20,5 );
    ReefAngel.StandardLights( Port4,11,5,15,55 );
    if (hour()>=9,3 && hour()<19,57)
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,19,55,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,18,55,15,100,15) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(11,5,15,55,15,100,15) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(11,35,17,55,15,100,15) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(18,35,3,5,15,100,15) );
    int x,y;
    x = 15;
    y = 2;
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // I/O Expansion
    byte bkcolor;
    x = 14;
    y = 39;
    // Parameters
    // Main Relay Box
    // Date and Time
That's exactly why I used that way.
The line means that port6 will be set to the status of port 5.
For opposite, you can simply add ! sign to invert the status of port 5.
    ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5));
bigHUN
Post by bigHUN »
Thank you so much Roberto
