Stuck with the I/O port #2 - ATO.
At this stage the waterlevel is high, so the I/O port#2 is ON, and I don't know how to code ATO OFF.
when the I/O#2 is OFF (low waterlevel) to turn the ATO ON with timer let say 60 second.
How to do this work around? Thanks in advance.........
ReefAngel.FeedingModePorts = Port1Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 265 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardATO( Port1,62 );
ReefAngel.StandardHeater( Port2,240,255 );
ReefAngel.StandardLights( Port3,8,55,20,5 );
ReefAngel.StandardLights( Port4,11,5,15,55 );
if (hour()>=9 && hour()<20)
ReefAngel.Wavemaker( Port5,5 );
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,5,19,55,15,100,15) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(10,5,18,55,15,100,15) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(11,5,15,55,15,100,15) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(11,35,17,55,15,100,15) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(18,35,3,5,15,100,15) );
//Float #1
if (ReefAngel.IO.GetChannel(1)) // if float 1 is triggered
ReefAngel.Relay.Off(Port8); // Turn Return off
ReefAngel.Relay.Off(Port7); // Turn Skimmer off
BuzzerOn(); // Turn Buzzer on
//Float #2
if (ReefAngel.IO.GetChannel(2)) // if float 2 is triggered
ReefAngel.Relay.On(Port1); // Turn AutoTopOff on
ReefAngel.Timer[1].Start(); // Start/Trigger timer
// Float #3
if (ReefAngel.IO.GetChannel(3)) // if float 3 is triggered
// Float #4
// if (ReefAngel.IO.GetChannel(4)) // if float 4 is triggered
// ReefAngel.Relay.On(Port7); // Turn Skimmer off
// Float #5
// if (ReefAngel.IO.GetChannel(5)) // if float 5 is triggered
// ReefAngel.Relay.Off(Port8); // Turn Return off
// BuzzerOn(); // Turn Buzzer on
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// I/O Expansion
byte bkcolor;
x = 14;
y = 39;
if ( ReefAngel.IO.GetChannel(a) ) bkcolor=COLOR_WHITE;
else bkcolor=COLOR_GRAY;
ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 53, ReefAngel.Params );
void BuzzerOn()
ReefAngel.PWM.SetActinic((now()%2)*100);
