Hi, here in the UK, it is very difficult (and expensive) to get hold of 470mv cal solution.
However, 400mv solution is easy to obtain and cheap!
So, how can I change the calibration so that I can calibrate with the 400mv solution, as I am sure it must be possible!
Look forward to your replies!
ORP Calibration using 400mv cal solution - is it possible?
Re: ORP Calibration using 400mv cal solution - is it possibl
It's embedded in the libraries, but if you want to change it, you can.
The issue is that everytime libraries get updated, it will revert back to 470.
But, I don't think you will be calibrating that many times either...
It's inside ReefAngel.cpp line 3636
And line 757
unsigned int iCal[2] = {0,470};
Params.ORP=map(Params.ORP, ORPMin, ORPMax, 0, 470); // apply the calibration to the sensor reading
Thats cool, no problem.
May be a silly question, but how do I open and edit the reef angel.cpp file??!!
any plain text editor.
Even notepad works
Even notepad works
Got it & Sorted!!
That was easy!!
That was easy!!
Ok, edited the .cpp file fine, recompiled and uploaded, but cal value still showing as 470mv?
I have double checked and the reef angel.cpp file has def been changed to 400mv instead of 470mv.
Do I need to do something to force the change into the compiler?
No, it should take it if the minute the file is saved.
I just tested and worked for me.
The ReefAngel.cpp file is located at Documents\Arduino\libraries\ReefAngel
Sorted, for some reason I see to have 2 groups of files - I changed the reef angel.cpp that was in applications on my mac, but didnt work as above. However, when I changed as in the file path from documents, now works!!
