IP Address
xtown90
IP Address
Post by xtown90 »
What IP address do I need for the portial and iPhone app?
Rob
modulok
Re: IP Address
Post by modulok »
You need your external IP. whatsmyip.org is a good place to find it.
xtown90
Re: IP Address
Post by xtown90 »
I used whatsmyip.org. It confirmed I have the correct ip address, but still does not work. I can see the settings when entering xxx.xxx.x.xxx:2000/wifi. Outside my LAN I can't connect.
Rob
dbmet
IP Address
Post by dbmet »
Do you have port forwarding turned on in your router?
modulok
Re: IP Address
Post by modulok »
Yup, you need to setup port forwarding. If you did it might not be working.
Use this site to check. canyouseeme.org (change the port to 2000)
xtown90
Re: IP Address
Post by xtown90 »
I used site. It says "Can not see your service on port 2000." So, I didn't set up the port forwarding correct.
Rob
