menus and lights
Ask in here.
rossbryant1956
menus and lights
Post by rossbryant1956 »
I am picking apart some code and using the pieces I like. Please explain to me what this does:
  ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port3Bit;
It looks like when a menu toggle is pressed it only turns off lights on the second outlet box. I will have lights on both of my outlet boxes. It obviously goes with this section:
  int x,y;
  ReefAngel.LCD.DrawMonitor( 15, 62, ReefAngel.Params,
  // Relay Expansion
  ReefAngel.LCD.DrawOutletBox( 12, 107, TempRelay );
I am still brand new at menus, so thanks in advance. BTW I am not using any of my LED\PWM ports at this time so if I don't need that part pls advise. Thx
Re: menus and lights
It tells the controller which ports will be used as lights.
If you have lights on both boxes, you need to set the correct bits for each box.
rossbryant1956
So then if I have lights on both boxes I need:
  ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port3Bit;
This look right? Thx
That works, but you can also remove this redundant code, because you are assigning a value to that same variable on the very next line.
