Wifi problem
creed
Wifi problem
Post by creed »
I had a power outage and my wifi stopped working. Slow green light flashing on module. I tried using the wifi setup tool again it goes through the whole thing but stay on the auto port forwarding when originally automatically configured the port forwarding. How can I get this thing working again?
00Warpig00
Re: Wifi problem
Post by 00Warpig00 »
If the light is flashing slow green the Wifi module should be connected to your access point. Sounds like your Router\Access point's DHCP server may have assigned a new IP address to your WiFi module.
Can you ping the WiFi module?
Nick
180G FOWLR
20GH QT#1
29G QT#2
creed
Re: Wifi problem
Post by creed »
How do I ping the wifi?
Re: Wifi problem
open command promp and type
ping xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx is your internal ip address
http://en.wikipedia.org/wiki/Ping_(networking_utility)
creed
Re: Wifi problem
Post by creed »
ok I did the ping. says 4 packets sent 4 recieved no loss on my internal ip addy. I assume this is good. What do I need to do next?
Re: Wifi problem
You should be able to connect to it by using the internal ip address, correct?
creed
Re: Wifi problem
Post by creed »
I can connect on iphone with the ip addy from the wifi setup utility only at home. The ip addy in the wifi utility is diffrent from my internal ip addy.
Re: Wifi problem
Ok, so you need to setup port forwarding on your router.
Check this site:
http://www.simpleportforwarding.com/
creed
Re: Wifi problem
Post by creed »
I tried the port forwarding not sure what I am doing!! What port to what port am I forwarding and what ip addy am I supposed to use?
dbmet
Re: Wifi problem
Post by dbmet »
Your forwarding port 2000 to whatever ip address the reefangel wifi module has..
creed
Re: Wifi problem
Post by creed »
I cannot figure this out!! Simple port forwarding asks for what port to what port to forward too, it also asks for what IP address to forward too. I don't know what values to enter?
dbmet
Wifi problem
Post by dbmet »
What kind of Wireless Router do you have?
creed
Re: Wifi problem
Post by creed »
Linksys wrt160n ver 3. Why won't it automatically set up port forwarding like it did in the past?
dbmet
Re: Wifi problem
Post by dbmet »
No Clue.. But I would check in the router settings to see what ip address the ReefAngel Wifi module has first.. Then you can forward port 2000 to that ip address.. I like to do everything manual in the router.
Maybe this site will help
http://portforward.com/english/routers/ ... ckland.htm
creed
Re: Wifi problem
Post by creed »
I finally got it working again!! After a week of trying. I never was able to figure out the manual port forwarding. I got frustrated and reset the router and went through the wifi setup wizard and it worked. The router set up the port forwarding without me having to do anything.
dbmet
Re: Wifi problem
Post by dbmet »
Great!!!
