Cannot upload code
cjrudy
Cannot upload code
Post by cjrudy »
I have generated some basic code using the wizard, when I try to upload it errors. Here is the code, and the error.
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,11,30,21,30 );
    ReefAngel.StandardLights( Port2,12,30,20,30 );
    ReefAngel.StandardHeater( Port3,778,788 );
    ReefAngel.StandardHeater( Port4,780,790 );
    ReefAngel.StandardATO( Port8,60 );
    ReefAngel.Portal( "cjrudy" );
And the error .............
Watchdog Timer
Version Menu
Wifi Attachment
Simple Menu
Binary sketch size: 30,478 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM9 -b115200 -D -Uflash:w:C:\Users\CRUDEW~1\AppData\Local\Temp\build3507860604110621111.tmp\sketch_dec30a.cpp.hex:i
Using Port : \\.\COM9
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
Re: Cannot upload code
Do you have RA or RA+?
Did you try any other serial port?
Sent from my Galaxy S3 using Tapatalk 2
cjrudy
Post by cjrudy »
I have the RA + and have selected it, I also have tried three different COM ports on my laptop
Does the controller reboot when you hit upload right after it displays "Rebooting Reef Angel Controller"?
cjrudy
Post by cjrudy »
No it does not reboot
Were you ever able to upload any code?
cjrudy
Cannot upload code
Post by cjrudy »
No, just got the RA+ up and running the day after Xmas. This was my first attempt to upload code
