ATO WaterLevel anomoly
Sebyte
Post by Sebyte »
I have the Water level expansion unit installed and working well.
My code uses the following to delay the turning on of the skimmer after feeding mode.
// Delay turning Skimmer back on
    ReefAngel.Relay.DelayedOn( Port1,60 );
My ATO pump is controlled by Port2, and I would like it also to be delayed like the skimmer. So I used the following code.
 // Delay turning ATO back on
    ReefAngel.Relay.DelayedOn( Port2,60 );
The result was that the ATO port 2 was in a permanent ON state.
I am wondering if there should only be one DelayOn function, and it should contain both ports. If so I am not sure what the syntax should be?
You cant have it be an ato port and be DelayedOn...you'll probably have to write a delay to your waterlevel function call.
Sebyte
Re: ATO WaterLevel anomoly
Post by Sebyte »
Many thanks, I will try another way.
You could wrap your WaterLevelATO function with an if statement checking if your skimmer is on or not.
Sebyte
Post by Sebyte »
I will give it a try. Thinking about it an IF ELSE loop should do it.
Thanks again.
Yeah, you might need the else or the pump may get "stuck" on. :)
