For some reason the wifi keeps disconnecting and I have to unplug the cable from the RA and re-plug it in. I t was working fine but now has been disconnecting for a few days, this morning I reset it up using the wifi utility and also upgraded the firmware, but it has not helped.
Any ideas.
Wi-Fi keeps disconnecting
Re: Wi-Fi keeps disconnecting
You may need to downgrade the firmware or use the beta test firmware.
http://forum.reefangel.com/viewtopic.php?p=17006#p17006
