Wizard time schedule
romebaby
Post by romebaby »
When I setup my reefangel for the first time a few weeks ago I could have sworn you could set each port for time individually. Now it ties them together for lighting, meaning if my main lights run 8 hours per day my refugium lights have to run for 16 hours a day, way too long. Am I mistaken or did something change in the wizard? How can this be changed so I can set my lights individually per port?
Re: Wizard time schedule
Yes.
We can hard code the times for your refugium.
What is the port you are using and what time do you want it on?
romebaby
Post by romebaby »
I put in my vote to change it back to simple time settings for each port. The way it is now is too limiting.
Simply choose the hard code settings and you can choose times for each port.
romebaby
Post by romebaby »
rimai wrote:Simply choose the hard code settings and you can choose times for each port.
I must be blind, where do you choose that?
Oh, when you run the wizard, it asks you how you want to save your settings-> hard code or internal memory
