Have used wizard to set time schedule but not working?
dazza1304
Post by dazza1304 »
Hi, as above.
Code from wizard is
ReefAngel.MHLights( Port3,0,40,23,30,5 );
ReefAngel.StandardHeater( Port6,249,251 );
ReefAngel.StandardFan( Port7,250,252 );
ReefAngel.StandardLights( Box1_Port5,23,30,23,32 );
My problem is the box 1 port 5 - I can manually turn on and off fine with portal and iphone app, but ReefAngel.StandardLights( Box1_Port5,23,30,23,32 ); doesnt seem to work - i.e. it does not come on from 23:30 to 23:32.
I cannot see anything wrong, so can anyone help please?
Sebyte
Re: Have used wizard to set time schedule but not working?
Post by Sebyte »
If you do not have a second relay box, then you do not need to specify the box number. Try removing Box_ from the function.
dazza1304
Post by dazza1304 »
Sorry, should have said, I do have a second relay box!
Please post your full code
dazza1304
Post by dazza1304 »
DrewPalmer04 wrote:Please post your full code
Below is the full code:
unsigned long lastLowSal=now();
InternalMemory.OverheatTemp_write( 255 );
ReefAngel.Relay.On( Port4 );
///// If salinity > 35.1 activate ATO pump until salinity < 35.1
if (ReefAngel.Params.Salinity<351) lastLowSal=now();
ReefAngel.Relay.Set(Port1,(now()-lastLowSal>120));
///// if skimmer cup full, turn off skimmer
bitClear(ReefAngel.Relay.RelayMaskOff,2);
else {
bitSet(ReefAngel.Relay.RelayMaskOff,2);
Does that port work otherwise? Port 5/6 have special circuitry for wave-makers...shouldn't be a problem but just something to try... The code looks fine but you did not post all of it...bit i dont know if its a code problen
dazza1304
Post by dazza1304 »
lnevo wrote:Does that port work otherwise? Port 5/6 have special circuitry for wave-makers...shouldn't be a problem but just something to try... The code looks fine but you did not post all of it...bit i dont know if its a code problen
Hi, yes port works fine, I can manually switch on and off etc.
dazza1304
Post by dazza1304 »
Hi I have had a little play around and have got it working.
I changed ReefAngel.StandardLights( Box1_Port5,23,30,23,32 );
to ReefAngel.MHLights( Box1_Port5,23,30,23,32,1 );
I think, though I might be wrong, when using the wizard, when setting a timer if you put the delay to 0, it doesn't populate a required field of the command ReefAngel.MHLights?
Maybe this caused my problem?
What kind of lights are they? Not sure how MH work but I guess since you put no delay it made them StandardLights..
dazza1304
Post by dazza1304 »
lnevo wrote:What kind of lights are they? Not sure how MH work but I guess since you put no delay it made them StandardLights..
It not actually lights - it's turning on an air pump to mix Red Sea reef energy before dosing!
The wizard obviously picks the MH function when choosing a timer schedule.
Not sure why it suddenly works, but got it doing what I want now, which is the main thing!
Odd for sure...
I would use the DosingPump function to make it clearer what your doing...nevermind its just for the mixing part...
Now that you have a working code base you can drop the wizard. :)
dazza1304
Post by dazza1304 »
lnevo wrote:Odd for sure...
Agreed!
