variables defined
Ask in here.
rossbryant1956
variables defined
Post by rossbryant1956 »
working with this bit of code:
void StandardHeater2(byte HeaterRelay, int LowTemp, int HighTemp)
    if (ReefAngel.Params.Temp[T2_PROBE] == 0) return;  // Don't turn the heater on if the temp is reading 0
    if (ReefAngel.Params.Temp[T2_PROBE] <= LowTemp && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(HeaterRelay);  // If sensor temperature <= LowTemp - turn on heater
    if (ReefAngel.Params.Temp[T2_PROBE] >= HighTemp) ReefAngel.Relay.Off(HeaterRelay);  // If sensor temperature >= HighTemp - turn off heater
where are those three variables defined; I imagine HeaterRelay is the port where the StandardHeater2 is plugged in, LowTemp and HighTemp are what they seem; but can't find where the original coder defined those variables.
He does have this snippet in the loop section, is this it?
StandardHeater2( Box1_Port6,776,780 ); //SumpHeater
Thx in advance.
variables defined
Probably as globals. Do you have a link to the coders full pde?
You can declare them above the setup() function.
Edit... Sorry just reread what was written... The variables are seclared as part of the function definition...
So when you say
void StandardHeater2(byte heaterrelay, int lowtemp, int hightemp)
Thats where the variables are declared...
When you call the function
StandardHeater2(Box1_Port6, 776, 780)
The variables get assigned...
rossbryant1956
Re: variables defined
Thanks, very helpful.
