mapping temperature ports
rossbryant1956
Post by rossbryant1956 »
got a new temp port tonite and it seems to have remapped all my ports based on the serial number of the probe, a known issue.
In my code, though, will my maps still work? Is the hardware port T2 (the middle one on the head unit) still T2 in my code? The cable still goes the same place, it just appears in a difference place on the portal.
Please advise. Thx
No. Easiest bet is to rerun the cables to match what you expect...
Otherwise you have to change your code to point to the new numbered probe for overheat and standard heater control.
