I have been trying to setup my 2nd RA system and I have been having issues with the 2nd Wifi module. I 1st one has been up and running for quite a few years with no issues using port 2000 and the portal and App home and away functions work without any problems
The new system is another story. I have configured the Wifi to use port 1000 and the ssid and password word are working correctly I can see the module on my router page and can ping the address with no issues and portforward tells me that the port is in use like I expected. But when I try connect to the RA unit using the app at home or away or from the portal it fails.
I can not access the webserver on the unit either when I type the IP in192.168.1.2:1000/wifi
Any ideas anyone??
Running 2 Wifi modules and have some Issues
Re: Running 2 Wifi modules and have some Issues
I'm taking you used putty or tera term to change the port, right?
Can you post the results "get e" command?
Yes I used tera term. below is my get e results
WiFly Ver 2.38.3, 01-15-2012 on RN-131
Beacon=100
Probe=5
Reboot=0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=ON
IP=192.168.1.2:1000
NM=255.255.255.0
GW=192.168.1.1
HOST=198.171.134.6:80
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
DNS=192.168.1.1
Name=www.reefangel.com
Backup=rn.microchip.com
FTP=208.109.14.133:21
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=abel1
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
Passphrase=6313443800
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
TimeEna=0
TIMEADR=129.6.15.28:123
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=ReefAngelWifi
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Sensor=0x0
SensePwr=0x0
<2.38.3> =0x24
ERR: ?-Cmd
<2.38.3> DeviceI
Beacon=100
Probe=5
Reboot=0
OPEN=
CLOSE=
REMOTE=
FlushSize=1420
MatchChar=0
FlushTimer=10
IdleTimer=3
CmdChar=$
IF=UP
DHCP=ON
IP=192.168.1.2:1000
NM=255.255.255.0
GW=192.168.1.1
PROTO=TCP,
MTU=1524
FLAGS=0x6
TCPMODE=0x0
BACKUP=0.0.0.0
DNS=192.168.1.1
File=wifly-GSX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=abel1
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon=5
SleepTmr=0
WakeTmr=0
Trigger=0x10
Autoconn=0
IoFunc=0x0
IoMask=0x20f0
IoValu=0x0
DebugReg=0x0
PrintLvl=0x0
TimeEna=0
Zone=7
Baudrate=57600
Flow=0x0
Mode=0x2
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
Password=
Format=0x0
Signal=0
Average=5
Interval=0x7
Sensor=0x0
SensePwr=0x0
<2.38.3> =0x24
ERR: ?-Cmd
<2.38.3> DeviceI
So, you get nothing if you browse: http://192.168.1.2:1000
Did you try a different port? One that is above 1024.
I like 8000 or 8080.
Just to confirm, the code loaded on your RA has wifi enabled, right?
no I didnt think of that I will try now and let you know
I changed the port to 8080 snd tried the webserver and nothing so I loaded a new code and made sure it had wifi enable and it did and so did the original code and it did.
I got the webserver working on port 8080 but that port was blocked by my provider so I switch to port 3000 and now all is working and now the temp probe errors on all ports? any ideas
Cool.
Was it like that before?
Did you try a different one?
Do the wires look ok?
