Hi,
I was wondering if it is possible to program a button on the iPhone app to turn on radions to a preset colour and intensity easily? i am already guessing yes.....
Tony
Preset Radion
Re: Preset Radion
Yes, but you would need to use a port on the relay box for that.
Is it ok?
Can you post your code?
Is it ok?
Re: Preset Radion
I am just looking into the possiblity of doing it.
What wanted to do is switch the radion which is running on blue at 10% to a preset 100% at 14k light? If you understand what i mean.
Tony
Tony
Re: Preset Radion
I know what you mean, but you need a trigger from the iphone app and the trigger would be a relay port.
So, when you override that port, the radions go into the preset value.
I do exactly this with mine. When I want lights on, I flip the relay on and the radions set themselves to a preset value.
Re: Preset Radion
Can i order the relay box with australian plugs?
Re: Preset Radion
No
Universal plugs is about 6 months out still. It will eventually be available, but not yet.
Re: Preset Radion
So I can just use adapters to convert to Australian format, that's cool I can live with that. I will order one shortly.
