ReefAngelContrib
thekameleon
ReefAngelContrib
I have seen lots of great ideas and code snippets on these forums. Is there a community driven contrib library that can be used to compile these efforts together?
Re: ReefAngelContrib
Yes, you can work on implementing them and request a patch after you have tested it.
The original libraries are hosted here: https://github.com/reefangel/Libraries
Use the dev branch, which should be the most updated. The master is the released version.
https://github.com/reefangel/Libraries/ ... ntributing
thekameleon
Thanks and last question... Is there a proven/best practice guide for developing... Reason I ask is. This whole thing looks to be single threaded and I assume using methods like "delay" would actually be bad thing as it could delay the rest of the processing in the loop method
Correct.
Single thread and delay is really bad practice. It will stop everything.
