Help Code Alternating Tunze Pumps
jayclaire
Please help me alter current code to run 2 Tunze pump at alternating mode
Roberto wrote this for me to run 1 Tunze pump at 75% from 2pm to 12am then from 12am to 2pm at 25%
if (hour()>14)
ReefAngel.PWM.SetDaylight (75);
ReefAngel.PWM.SetActinic (75);
ReefAngel.PWM.SetDaylight (25);
ReefAngel.PWM.SetActinic (25);
New settings:
2 Tunze pumps to run at 75% from 12pm -12am at 75% alternating every 60 seconds then from 12am-12pm at 25%
Thank you
~JaY
if (hour()>14)
New settings:
Thank you
~JaY
Re: Help Code Alternating Tunze Pumps
Try this:
if (hour()>14)
ReefAngel.PWM.SetDaylight (now()%(120)<60?25:75);
ReefAngel.PWM.SetActinic (now()%(120)<60?75:25);
jayclaire
Thank you for the fast respond - I'll give this a try.
jayclaire
Hey Roberto can you please change the alternate time to every 2 hours instead of every 60 seconds.
Thanks - JaY
Thanks - JaY
jayclaire
Is this correct?
if (hour()>14)
ReefAngel.PWM.SetDaylight (now()%(10)<2?25:75);
ReefAngel.PWM.SetActinic (now()%(10)<2?75:25);
if (hour()>14)
I think you need to % 14400 with the remainder < 7200 (so modulus the day by 4 hours (14400) and remainder less than 2 hours (7200)
Previously it was modulus 2 minutes (120) with the remainder being less than 1 minutes (60)
The code uses seconds and not hours.
120 seconds = total cycle
60 seconds = time to switch from 1st half to 2nd half of cycle
You can even make asymmetric waves... If you make total cycle 120 and switch 20, you will have 1st cycle duration at 20seconds and 2nd half at 100s.
jayclaire
Okay how about this?
if (hour()>14)
ReefAngel.PWM.SetDaylight (now()%(4*60*60)<(2*60*60)?25:75);
ReefAngel.PWM.SetActinic (now()%(4*60*60)<(2*60*60)?75:25);
if (hour()>14)
jayclaire
lnevo wrote:I think you need to % 14400 with the remainder < 7200 (so modulus the day by 4 hours (14400) and remainder less than 2 hours (7200)
Thanks lnevo - Are u the same lnevo in MR?
